Bil preparerad med Glare
Postat: 07 jun 2012 13:28
Jag hittade denna tråd på ett annat forum:
http://www.detailingworld.co.uk/forum/s ... p?t=265743
Hoppas att det är ok att jag länkar till den :).
Re: Bil preparerad med Glare
Postat: 07 jun 2012 13:41
av WaxDog
Här snackar vi väldokumenterad polering :mrgreen:
Kul att läsa att folk är nöjda med produkten.
Postat: 07 jun 2012 23:07
av Rednales
Reagerar lite på följande mening: "Remember this was an entirely non abrasive system"
Enligt detta så skall Glare inte ha någon slipande effekt utan fyller endast upp reporna, stämmer det?
Postat: 08 jun 2012 07:53
Rednales skrev:Reagerar lite på följande mening: "Remember this was an entirely non abrasive system"
Jag uppfattar det som om Spider och Micro Finish innehåller "slipmedel", men är mer osäker på KnockOut även om den beskrivs som "heavy cut":
GLARE MICRO-FINISH is a revolutionary micro compound developed with our exclusive Glassplexin formulation. GLARE MICRO-FINISH has the smallest and finest abrasive particles added to remove light to moderate levels of oxidation and micro scratches without scratching or harming the applied surface.
GLARE Spider with Glassplexin is the most advanced swirl removing product ever created. Utilizing a unique chemical process of ultra pure metal interlinked fusion to Glassplexin particles, GLARE SPIDER will physically and chemically remove circular swirls and the appearance of spider webs in the paint, including on black paint even when viewed in direct sunlight.
GLARE KNOCKOUT is a heavy cutting compound that contains our proprietary Glassplexin formulation and unlike other compounds will not scratch paint. Fills in the scratches permanently. Again, like all GLARE products, this is a product that does not contain any type of carnauba wax, synthetic polymer wax, or resins or abrasives. GLARE KNOCKOUT is the most aggressive product in the GLARE line and is designed to remove and repair the heaviest levels of oxidation and scratches in a safe and effective manner through both physical and advanced chemical means. Will not sratch paint!! It has been designed to be as aggressive as possible without being abrasive.
Jag har åtminstone lyckas få bort ytliga repor samt noterade även hologram på sonens Ford Ka. Det tyder ju på att åtminstone Spider och Micro Finish har en polerande effekt.
