Pastavax,
Postat: 03 apr 2010 13:59
av Göran
Finns det nå´t pastavax med doft?
Re: Pastavax,
Postat: 03 apr 2010 14:12
Detta luktar otroligt gott...
High Definition Wax For the Ultimate Finish
Designed to be used on fine quality paintwork where the owner wishes to achieve a concours winning shine. High Definition Wax imparts a lustre and depth of shine normally only found on the most expensive hand built cars.
High Definition Wax contains a carefully balanced complex blend of durable polymers, Carnauba and microcrystalline waxes, combined with selected solid saturated hydrocarbons and oils. Surfaces treated with High Definition Wax display very high gloss combined with exceptional resistance to environmental contaminants e.g. salt, detergents, UV light, acid rain, industrial fallout, etc. The product is completely free of abrasives, water and emulsifiers.
High Definition Wax represents a major step forward in product advancement and combines the ultimate finish with the ultimate in protection. It is designed to meet the needs of car owners wishing to achieve a finish to concours standard.
High Definition Wax is simply the finest car wax Autoglym has ever produced.
Re: Pastavax,
Postat: 07 apr 2010 08:22
av tumba25
pastavax? Som spagetti?
Re: Pastavax,
Postat: 07 apr 2010 09:25
av Tantrum
Pastavaxer kommer i burk och är fasta i konsistensen
Jag älskar Meguiars grejer. Jag har Gold Class, NXT 2.0 och #26 i pastaform och alla luktar helt fantastiskt!
Re: Pastavax,
Postat: 07 apr 2010 11:02
av Torlejf
Dodo Juice luktar inte fisk dom heller direkt.
Köper alltid godis efter en sån behandling då man varit sugen på det hela jäkla tiden pga lukten.
Mvh. David.
Re: Pastavax,
Postat: 07 apr 2010 11:12
av sodisodi
Torlejf skrev:Dodo Juice luktar inte fisk dom heller direkt.
Mvh. David.
Endera så köper du mycket varje gång....
eller så putsar du bilen ofta ......(varje svensk äter 17Kg godis per år)
Re: Pastavax,
Postat: 08 apr 2010 16:06
av Göran
Tantrum skrev:Pastavaxer kommer i burk och är fasta i konsistensen
Vart kan man köpa dessa?
Re: Pastavax,
Postat: 08 apr 2010 18:58
av Tantrum
Vet faktiskt inte. Meguiars hade t ex. inga pastavaxer i sin monter på Elmia, så jag är inte säker på att de tar in dem till Sweden. Men vilken random engelsk webshop som helst lär ha dem allihop
Re: Pastavax,
Postat: 10 apr 2010 01:22
av WaxDog
Tror faktiskt inte jag stött på nåt pastavax som inte luktar mer eller mindre gott.
Skulle vara nåt unket vax farsan hade när man var barn då
Har faktiskt ingen aning om vilken ingrediens som gör att dom luktar gott men jag sätter en peng på Carnuban.
Håller med Nisse, HD Vaxet från Autoglym luktar som något man vill sätta tänderna i.
Re: Pastavax,
Postat: 10 apr 2010 01:52
av MAX
Göran skrev:Finns det nå´t pastavax med doft?
Beror ju på vilken doft du är ute efter
Har själv testat biltemas brilljantvax nu både på min testhuv och min nya astra combi(superduper högglanspolerad)och det vete sjuttsingen vad det luktar men det luktar alla fall nånting
Men blank är det(pga underarbetet)och lämnar en hal yta med små gulliga vatten pärlor
hållbarheten har jag ingen aning om men det visar sig beroende på hur jag tvättar
max.
Re: Pastavax,
Postat: 10 apr 2010 09:09
av Göran
Har beställt en burk av mortil nu, Meguiars Next gen fast som pasta!
