Autosmart Brisk , blekmedel som kan göra plast lila ??
Postat: 31 dec 2011 18:26
Läste på ett engelsk forum att Autosmart Brisk kan missfärga plast så den kan bli missfärgad åt det lila hållet.
Det ska visst bero på blekmedlet , som oxå finns i andra interiörs cleaners ..
Det har väl varit på tapeten att Concept H.D. Fabric Cleaner oxå har blekmedel ..
I only use g101 on interiors. Brisk is good but can leave a purple mark on some interior plastics if you are not careful. Get a 5ltr if g101 put it in a 25ltr drum and fill the rest with water. At 5:1 it will pretty much shift anything and can be diluted down further for light soiling and dirt.
This is correct, Brisk is only for fabrics and carpets and should not really be used on plastics due to the optical brighteners.
Yep the optical brighteners do leave a purple look to plastics.
Länk : http://www.detailingworld.com/forum/sho ... p?t=242694
