Forumet uppgraderat
Postat: 04 jul 2010 16:59
Forumet är uppgraderat till phpBB 3.0.7-PL1. Changeloggen är nedanför. Om det är någon del av changeloggen som behöver förklaras så är det här en bra tråd att fråga i.
Have fun!
/D
Have fun!
/D
- [Fix] Allow ban reason and length to be selected and copied in ACP and subsilver2 MCP. (Bug #51095)
- [Fix] Force full date for board online record date.
- [Fix] Correctly reset login keys if passed value is the current user. (Bug #54125)
- [Fix] Correctly set last modified headers. (Bug #54245, thanks Paul.J.Murphy)
- [Fix] Show correct HTML title when reporting private messages. (Bug #54375)
- [Fix] Correctly exclude subforums from ATOM Feeds. (Bug #54285)
- [Fix] Do not link to user profile in ATOM feed entry if post has been made by the guest user. (Bug #54275)
- [Fix] Make word censoring case insensitive. (Bug #54265)
- [Fix] Fulltext-MySQL search for keywords and username at the same time. (Bug #54325)
- [Fix] Various XHTML and CSS mistakes in prosilver and subsilver2. (Bugs #54705, #55895, #57505, #57875 - Patch by HardStyle)
- [Fix] Correctly show topic ATOM feed link when only post id is specified. (Bug #53025)
- [Fix] Cleanly handle forum/topic not found in ATOM Feeds. (Bug #54295)
- [Fix] PHP 5.3 compatibility: Check if function dl() exists before calling it. (Bug #54665)
- [Fix] PHP 5.3 compatibility: Disable E_DEPRECATED on startup to keep set_magic_quotes_runtime(0) quiet. (Bug #54495)
- [Fix] Correctly replace table prefix before inserting schema data into the database. (Bug #54815)
- [Fix] Correctly take post time instead of topic time for the overall forum feed statistics row. (Bug #55005)
- [Fix] Posting errors with CAPTCHAs using user::add_lang(). (Bug #55245)
- [Fix] Use memcache::replace() instead of memcache::set() for existing keys to prevent problems.
- [Fix] Check for required functions in eAccelerator. (Bug #54465)
- [Fix] Use correct RFC 3339 date format in ATOM feed. (Bug #55005)
- [Fix] Do not deliver topics from unreadable or passworded forums in the news feed. (Bug #54345)
- [Fix] Restore user language choice to compiled stylesheets. (Bug #54035)
- [Fix] Add missing language entries. (Bug #55095)
- [Fix] Do not permit unauthorised users to delete private messages from folder listing. (Bug #54355)
- [Fix] Correctly check for empty strings in custom profile fields. (Bug #55335)
- [Fix] Use correct options to parse BBCodes in signatures when previewing PMs.
- [Fix] Correct rendering of prosilver quick reply under IE6. (Bug #54115 - Patch by Raimon)
- [Fix] Correct wording for "How do I show an image below my username" question answer in FAQ. (Bug #23935)
- [Fix] Handle export of private messages where all recipients were deleted. (Bug #50985)
- [Fix] Correctly get unread status information for global announcements in search results.
- [Fix] Correctly handle global announcements in ATOM feeds.
- [Fix] Use correct limit config parameter in the News feed.
- [Fix] Restrict search for styles/../style.cfg to folders. (Bug #55665)
- [Fix] Add ability to disable overall (aka board-wide) feed.
- [Fix] Do not pass new_link parameter when creating a persistent connection with mysql. (Bug #55785)
- [Fix] Improved search query performance through sorting words by their occurance. (Bug #21555)
- [Fix] Correctly move sql_row_pointer forward when calling sql_fetchfield() on cached queries. (Bug #55865)
- [Fix] Remove item limit from "All forums" feed.
- [Fix] Do not use group colours for usernames on print view. (Bug #30315 - Patch by Pasqualle)
- [Fix] Pagination of User Notes in MCP uses two different config values. (Bug #56025)
- [Fix] List hidden groups on viewprofile where the viewing user is also a member. (Bug #31845)
- [Fix] Sort viewprofile group list by group name.
- [Fix] Strictly check whether a moderator can post in the destination forum when moving topic. (Bug #56255)
- [Fix] Added some error handling to the compress class.
- [Fix] Correctly determine permissions to show quick reply button. (Bug #56555)
- [Fix] Do not unsubscribe users from topics replying with quickreply. (Bug #56235)
- [Fix] Don't submit when pressing enter on preview button. (Bug #54395)
- [Fix] Load reCAPTCHA over https when using a secure connection to the board. (Bug #55755)
- [Fix] Clarify explanation of bump feature setting. (Bug #56075)
- [Fix] Properly paginate unapproved posts in the MCP. (Bug #56285)
- [Fix] Do not duplicate previous/next links in pagination text of moderator logs and user notes in MCP for subsilver2. (Bug #55045)
- [Fix] Do not automatically unsubscribe users from topics, when email and jabber is disabled.
- [Fix] Don't send activation email when user tries to change email without permission. (Bug #56335 - Fix by nrohler)
- [Fix] Replace hard coded "px" with translated language-string. (Bug #52495)
- [Fix] Correctly hover list menu in UCP and MCP for RTL languages. (Bug #49945)
- [Fix] Correctly orientate quoted text image on RTL languages. (Bug #33745)
- [Fix] Deprecate $allow_reply parameter to truncate_string() (Bug #56675)
- [Fix] Fall back to default language email template if specified file does not exist. (Bug #35595)
- [Fix] Update users last visit field correctly when changing activation status. (Bug #56185)
- [Fix] Database updater now separates ADD COLUMN from SET NOT NULL and SET DEFAULT, when using PostgreSQL <= 7.4 (Bug #54435)
- [Fix] Styles adjustment to correctly display an order of rtl/ltr mixed content. (Bugs #55485, #55545)
- [Fix] Fix language string for PM-Reports refering to post-data. (Bug #54745)
- [Fix] Do not store email templates in database. (Bug #54505)
- [Fix] Fix javascript bug in the smilies ACP. (Bug #55725)
- [Fix] Unify BBCode Selection across browsers. (Bug #38765)
- [Fix] Allow convertors to read in configuration from files. (Bug #57265 - Patch by Dicky)
- [Fix] Fix problems with firebird by no longer using 'count' as a column alias. (Bug #57455)
- [Fix] Small language correction for the FAQ page. (Bug #57825)
- [Fix] Restrict search for language/../iso.txt to folders. (Bug #57795)
- [Fix] Make user_email_hash() function independent from system's architecture. (Bug #57755)
- [Fix] Correct behavior of "force_approved_state" when value is false. (Bug #57715)
- [Fix] Global announcements could not be accessed on a board using Firebird as the database server. (Bug #57525)
- [Fix] BBCode parser now uses the user object for all settings rather than taking some from the template object (Bug #57365)
- [Fix] Ensure a database connection is available before logging general errors. (Bug #57975)
- [Fix] Do not delete unrelated attachments when deleting empty forums. (Bug #57375)
- [Fix] Update: Store expected resulting file contents in cache and do not suggest further merges if the contents match, also fixes infinite merge loop (Bug #54075)
- [Change] Move redirect into a hidden field to avoid issues with mod_security. (Bug #54145)
- [Change] Log activation through inactive users ACP. (Bug #30145)
- [Change] Send time of last item instead of current time in ATOM Feeds. (Bug #53305)
- [Change] Use em dash instead of hyphen/minus as separator in ATOM Feeds item statistics. (Bug #53565)
- [Change] Alter ACP user quick tools interface to reduce confusion with the delete operation.
- [Change] Send statistics now check for IPv6 and send private network status as a boolean.
- [Change] Split "All topics" feed into "New Topics" and "Active Topics" feeds.
- [Change] Forum feed no longer includes posts of subforums.
- [Change] Show login attempt CAPTCHA option in the captcha plugin module.
- [Change] It is no longer possible to persist a solution for the login CAPTCHA.
- [Change] SQLite is no longer autoloaded by the installer. (Bug #56105)
- [Change] Friends and foes will not show up as private message rule options if their respective UCP modules are disabled. (Bug #51155)
- [Change] Offer for guests to log in for egosearch and unreadposts search before the search permissions check. (Bug #51585)
- [Change] Show warning box for users of PHP < 5.2.0 about phpBB ending support.
- [Change] Disallow deleting the last question of the Q&A CAPTCHA.
- [Change] Tweak Q&A CAPTCHA garbage collection.
- [Change] Show a proper preview for the Q&A CAPTCHA. (Bug #56365)
- [Change] Speed up topic move operation by adding an index for topic_id on the topics track table. (Bug #56545)
- [Change] Warn users about potentially dangerous BBcodes.
- [Feature] Ability to use HTTP authentication in ATOM feeds by passing the GET parameter "auth=http".
- [Feature] Add INTTEXT token type to custom bbcodes to allow non-ASCII letters in html attributes.
- [Feature] Add ability to enable quick reply in all forums.
