DAS-6 PRO Plus - 15mm Dual Action Polisher
Postat: 29 okt 2014 15:26
Tycker denna maskin verkar minst lika intressant som den versionen med 21mm slag så jag skapar en tråd för den här.
Vågar man gå på en sån här maskin istället för originalet?
Blir det mer vibrationer i denna är originalet?
Funkar den 125mm stödplattan som finns som tillbehör bra, ökar vibarionerna?
http://www.cleanyourcar.co.uk/index.php ... uctId=1452
Price: £159.95
Saxat från sidan:
Price: £159.95
Saxat från sidan:
The all new DAS-6 PRO Plus we believe is quite simply is the best random orbital car polisher available on the market today.
We've taken the standard DAS-6 PRO and improved it with a all new body design and larger 15mm throw. The results are simply a more ergonomic machine which not only runs smoother, but polishes faster. The unique 15mm throw we feel is the optimum throw for a dual action polisher. Whilst remaining extremely useable it's possible to cover more surface area, effectively removing more swirls, sctaches and holograms faster and with less effort. Not only that but because of the larger orbit the machine has noticebly less vibration compared to other dual action polishers.
This makes the DAS-6 PRO Plus the perfect machine for correcting, refining and finishing all types of paintwork.
The machine itself comes supplied with a UK 240v plug, is fully CE marked and has the peace of mind of a 1 year manufacturers warranty. Improvements include a special anti-kink 6 meter cable and a D-Handle. We are also including a special embroidered canvas carry case with every machine, perfect for storing the machine and accessories whilst not in use.
Specifications:
Orbit Size: 15mm
Backing Plate Thread Size: 5/16" (same as Porter Cable, G220 and UDM's)
Variable 6 Speed Dial
Speed: 1,800 to 4,800 opm
Weight - 2.3kg (approx)
Supplied with a 150mm (6")
Fits 6" and 6.5" polsihing pads
Key Features:
Heavy Duty 880w Motor
CE marked / 240v with UK plug
6 Meter Heavy Duty Cable
D-Handle
Canvas Carry Case
Aluminium Gear Housing Cover
CNC Finished Gears
Electricity Feedback Circuit
1 Year UK Manufacturer Warranty
