Tips på vax...?
WaxDog
Re: Tips på vax...?
Inlägg av WaxDog » 14 jan 2011 23:32
Finns massor av produkter som luktar gott...har lite märkliga testprodukter som jag absolut skulle kunna käka/dricka upp om jag inte visste vad det var i :)
Abyss: Det är inte nyttigt!! Låt bli... :mrgreen:
WaxDog - För din bil och båt
http://www.waxdog.se
Gunther
Re: Tips på vax...?
Inlägg av Gunther » 14 jan 2011 23:44
Här är info hur man kan mäta bra reflektioner!
http://www.detailingworld.co.uk/forum/s ... ight=astra
http://www.amecal.com/downloads/UKASUpd ... rement.pdf
A glossmeter measures specular reflection. The light intensity is registered over a small range of the reflection angle. The intensity is dependent on the material and the angle of illumination. In case of non-metals (coatings, plastics) the amount of reflected light increases with the increase of the illumination angle. The remaining illuminated light penetrates the material and is absorbed or diffusely scattered dependent on the color. Metals have a much higher reflection and are less angle dependent than non-metals.
A glossmeter gives the amount of reflected light from a sample, compared to that reflected from a black glass calibration standard with a defined refractive index. The result is independent of the amount of incident light. The gloss value of the reference standard is defined to be 100 gloss units. Materials with a higher refractive index can have a measurement value above 100 gloss units. For transparent materials, the gloss can be increased by multiple reflections in the bulk of the material. Due to the high reflectivity of metals, values as high as 3500 gloss units can be obtained. For these applications it is common to use percent reflection of incident light rather than gloss units.
Glossmeters usage procedures. as well as their defined angles of measurement, are internationally standardized to allow comparison of measurement values. Angle of illumination is the most important criterion. To clearly differentiate between high gloss and low gloss, several different measurement angles are used, with incident angles of 20, 60, and 85 degrees the most common. The 20 degree angle is normally used for high gloss surfaces, the 60 degree angle for medium gloss surfaces, and the 85 degree angle for low gloss surfaces. Other angles of measurement are used for specific applications, such as 75 degrees for plastic film, and 45 degrees for vinyl siding.[
Kapten Haddock
Re: Tips på vax...?
Inlägg av Kapten Haddock » 15 jan 2011 00:43
Lyxwaxet är väldigt trevligt men som sagt prislappen är lite väl i sverige, men beställer man från England för under 300kr blir det genast trevligare:)
Annars har ju Gunther många trevliga alternativ till grymt bra priser, ungefär samma pris som i England!!!
Ett bilvax kan man som kemist få att dofta i princip hur som helst, även om det är otroligt svårt att hitta riktigt bra dofter.
MVH/
jujimbo
Re: Tips på vax...?
Inlägg av jujimbo » 15 jan 2011 00:54
Jag har en burk med blit hamber autobalm den gillar jag skarpt men det är ju svårjobbat men väldigt trevligt slutresultat med den.
Jimmy Larsson
Re: Tips på vax...?
Inlägg av Jimmy Larsson » 16 jan 2011 16:00
Oerhört tacksam för alla tips!
Beställde en burk Collinite 915 igår, känns rätt till Impalan.
Tänkte även köra det på min Golf Mk1 som också är klarröd. Men får se, den ska jag nog testa lite olika på så man får prova på och se skillnader på olika vax... :D
jesprut
Re: Tips på vax...?
Inlägg av jesprut » 16 jan 2011 16:36
Jiiins skrev:Hej!
Om du tvekar vilken av Collinite waxerna du ska köpa`!?.......Så kan du köpa här till ett bra pris o testa o se vilken som funkar bäst :jeps http://cgi.ebay.com/ebaymotors/Collinit ... iesQ5fGear
Tack för tipset! köpte med en gång, ska bli kul att testa nu till våren :)
Jimmy Larsson
Re: Tips på vax...?
Inlägg av Jimmy Larsson » 16 jan 2011 19:24
Ja justja, den där Ebay länken hade jag helt glömt bort.
Blir ju typ samma pris för en 915 som det där kittet från USA med 915, 476 och 845...är det fullstora burkar?
Men men, jag blir nog väldigt nöjd när mitt paket ifrån WaxDog dimper ner också...eller hur Andreas! :D
WaxDog
Re: Tips på vax...?
Inlägg av WaxDog » 16 jan 2011 19:34
Lita på det! Stora beställningar belönas alltid med något extra :nicka
Hoppas du blir nöjd.
Jimmy Larsson
Re: Tips på vax...?
Inlägg av Jimmy Larsson » 20 jan 2011 01:32
Det slutade med att jag valde Collinite 915 och jag fick hem det idag...mmmm vad gott det luktar!!! Längtar redan tills jag får smeta in Impalan med vax.. :D
Blev även en flaska Autoglym Bodywork Shampoo Conditioner, den luktade också väldigt gott!!!
Tror jag fått ihop ett rätt så bra kitt till gubben nu. Det består utav:
ValetPro Protectant till däcken, blandat 1:2 (Soft Sheen)
ValetPro Billberry fälgrengöring. Kan man använda den på kromfälgar eller ska han bara köra den på sina andra bilars alu fälgar?
Collinite 915
Lammullsvante
ValetPro Large Drying Towel
Dodo Juice Fantastic Fur microfiberduk
Hoppas gubben blir glad! :D
WaxDog
Re: Tips på vax...?
Inlägg av WaxDog » 20 jan 2011 01:52
Det kittet blir finfint till hans grymma (och skitstora) bil :)
Ska du lägga GLARE Professional Polish på din egen bil? Den fick inte gubben alltså... :mrgreen:
Jimmy Larsson
Re: Tips på vax...?
Inlägg av Jimmy Larsson » 20 jan 2011 02:39
Nee, den behåller jag för mig själv... :D
Får se till våren vad det hamnar på, finns några att välja på. Förhoppningsvis har jag fart på min Golf Mk1 igen då och den behöver en polering och skydd. Solid-Röd.
Hur många bilar räcker det till ungefär?
WaxDog
Re: Tips på vax...?
Inlägg av WaxDog » 20 jan 2011 13:14
Du använder det i 2 steg så med dubbla påläggningar på bilen ska det räcka till 3 bilar.
Golf MK1 storlek kanske 4 bilar.
Eller 2 bilar som far din äger :mrgreen:
Gunther
Re: Tips på vax...?
Inlägg av Gunther » 20 jan 2011 22:17
Jättefint paket! Jag hoppas han bli nöjd med alla produkter! ;)
Bilberry wheelcleaner kan man använda på kromfälgar, alu fälgar,.... :jeps Men glöm inte att spädda produkten...
Jimmy Larsson
Re: Tips på vax...?
Inlägg av Jimmy Larsson » 21 jan 2011 00:37
Jag har spätt den 1:3 ungefär...ska man kanske spä den ännu mer?
Jag kör 1:3 själv nu när jag använder den, just på navkapslarna på min Passat, och det fungerar perfekt!
Gunther
Re: Tips på vax...?
Inlägg av Gunther » 21 jan 2011 18:51
Du kan spädda Bilberry Wheelcleaner till 1:10 eller 1:5. Jag använda mesta 1:5 utspäddning
Men enligt tillverkaren är 1:3 perfekt...
jesprut
Re: Tips på vax...?
Inlägg av jesprut » 21 jan 2011 22:02
Fick hem ett paket från staterna i veckan :) Ska bli kul att testa nu till våren ;)
Re: Tips på vax...?
Inlägg av Jiiins » 21 jan 2011 22:08
jesprut skrev:Fick hem ett paket från staterna i veckan :) Ska bli kul att testa nu till våren ;)
Det funkade fint även för dej :cheers
jesprut
Re: Tips på vax...?
Inlägg av jesprut » 22 jan 2011 10:53
Visst gjorde de det, köpte i fredags och det låg i brevlådan i onsdags:)
Re: Tips på vax...?
Inlägg av Jiiins » 22 jan 2011 12:27
Jag blev själv väldigt förvånad över att sakerna kom så fort. Till och med fortare än när man beställt ifrån andra ställen inom Sverige ;)
PS. Flaskan ska du skaka länge o väl o när du tycker du skakat länge, så ska du skaka den ett tag till :)
Har jag för mej att jag läst någonstans om den? Har själv ej hunnit testa någon av dom ännu :jeps
jesprut
Re: Tips på vax...?
Inlägg av jesprut » 22 jan 2011 15:07
Okej tackar för tipset om skakning :)
Hur är det nu då? 915 till mörka lacker och 476 till ljusa ? vart ska man ha 845 till ? :)
När ni skriver lägga på för hand menar ni då bokstavligen att lägga på vaxet med bara händerna då? eller ska man ha någon vaxapplikator eller MF duk? :)
Testade att lägga på lite 476 på baksidan av telefonen med bara fingrarna och det blev skit bra så jag la ett lager till :P
