Polycharger Wax Booster
Kategoriregler
Låst
WaxDog
Inlägg av WaxDog » 29 aug 2012 23:59
På ingående!
Polycharger™ CH2 Wax Booster is the prescription for solvent-based liquid waxes. Polycharger™ Wax Booster boosts carnauba waxes for incredible shine and protection!
Works with paint sealants to form an unbeatable layer of protection! Your paint will shine and bead water like crazy for months! Polycharger™CH2 Wax Booster is the prescription for solvent-based liquid waxes, including most paint sealants. Polycharger™ CH2 Wax Booster works with most popular consumer brand products, including Meguiar's and Mothers, and boutique car wax products from brands like Griot's Garage, Pinnacle, SmartWax and Wolfgang. See the compatibility list for complete details. Polycharger™ effectively increases car wax protection (length and level) by 400% or more. When properly maintained by regular washing, paint protected by a Polycharger™ boosted car wax will retain their shine and protection for twenty weeks or more. Comparatively, most car wax finishes loose water-beading, shine and slickness after only four to six washes.
Key Benefits
•Increases level of protection provided by waxes and sealants by 400%
•Lasts for months
•Compatible with most popular consumer products
Instructions
•To be used with solvent-based liquid waxes and sealants.
•Follow dosing instructions on compatibility chart included in kit.
•Apply to surface following product directions.
Note: For use with solvent-based products only.
Recommended Surfaces
•Clear coated surfaces
•Painted surfaces
•Plastic & glass surfaces
Contents
Polycharger™ CH2 Wax Booster, 2 oz. vial
Dosing dropper
Mixing bottles
Eight page color Product Compatibility Guide
Dosing Chart
Kit box
WaxDog - För din bil och båt
http://www.waxdog.se
WaxDog
Re: Polycharger Wax Booster
Inlägg av WaxDog » 09 sep 2012 13:42
Nu finns Polycharger Booster på hyllan.
Anabola Sterioider för flytande vax och lackskydd.
http://www.waxdog.se/product.php?id_product=364
WaxDog
Inlägg av WaxDog » 09 sep 2012 13:56
Denna boostern ökar hållbarheten med ca 4ggr så det är inget som varar för evigt så det bör inte vara några problem. Men du bör väl inte lämna bilen till lackeraren direkt efter du vaxat din bil med vax som är boostat =)
Inlägg av Manor » 09 sep 2012 15:10
Vad tror du om att köra detta ovanpå Glare?
Kanske är det bättre att köra Glare Rapid Action enligt formeln samma + samma = bäst :).
WaxDog
Inlägg av WaxDog » 09 sep 2012 16:24
Borde funka utmärkt till Glares produkter, tänker själv köra den kombon.
Bör ju bli en slutprodukt med Glares och Ultimas kvaliteter mixat :best
Inlägg av Göran » 25 nov 2012 17:53
Inlägg av Göran » 11 jan 2013 20:16
Jag kommer att lägga ut en guide hur man mixar Menzernas vax med denna! :jeps
WaxDog
Inlägg av WaxDog » 11 jan 2013 23:06
Kanon Göran, den mixturen saknas i bladet om hur man ska mixa alla olika vaxer på marknaden.
Tackar för det! :jeps
Låst
