Why spend a raid fixing a basement nightclub that pays out no loot? Because the Hotel Panorama Disco Room puzzle is one of those rare ARC Raiders secrets that makes the map feel hand-built, not just dressed up for extraction runs; bring spare wires, batteries, or purchase Arc Raiders Items before you head in, because arriving empty-handed turns the whole trip into sightseeing with extra gunfire. Honestly, I like that it wastes your time a little.
Where the Hotel Panorama Disco Room Puzzle Fits in Riven Tides
The location players keep missing
The disco room sits in the southeastern basement area of Hotel Panorama Azzurro, inside the Riven Tides update area. The hotel itself is a big landmark, but the party room is easy to pass because most squads move through basements quickly: grab materials, check corners, leave before someone hears you.
Look for the stage-like space, damaged audio gear, dark lighting fixtures, and repair prompts around nearby walls or utility boxes. From what I have seen, the puzzle feels less like a quest marker and more like an old-school environmental secret. No glowing arrow. No polite tutorial voice. Good.
What actually happens when it works
Once the repair chain is complete, the room changes sharply. The lights come alive, the disco ball drops or starts spinning, and music fills the basement. It is not subtle, which is both the charm and the problem.
The Hotel Panorama Disco Room puzzle does not appear to hand out normal rewards like weapons, XP, or rare loot. Its reward is atmosphere, screenshots, and the smug satisfaction of knowing a map secret before half the lobby does. That may sound thin, but in a tense extraction game, a weird little dance floor has more personality than another crate of scrap.
How to Complete the Hotel Panorama Disco Room Puzzle
Bring the right repair items before entering
Do not count on finding every component inside the hotel. The requirements can vary by raid instance, so pack a small buffer if you are serious about triggering the event. Personally, I would bring at least three electrical materials and accept the inventory tax.
Batteries for power-related repair points
Wires for broken panels or speaker connections
Voltage converters if the instance asks for heavier electrical work
Yes, that means leaving less room for profitable loot. That tradeoff is the whole point. If your squad is farming efficiently, skip it. If you are mapping secrets or recording footage, prepare properly.
The repair sequence that usually works
1) Enter the Hotel Panorama Azzurro basement from a route your squad can defend. Clear nearby AI and listen for Raiders before touching any prompt.
2) Find the damaged speaker system near the stage or main dance area. Repair it first if the prompt appears, because the sound setup seems to be the backbone of the activation chain.
3) Sweep the walls, corners, utility boxes, and nearby side rooms for additional electrical repair points. Check slightly above or outside the immediate room if one prompt seems missing. This part is annoyingly easy to overlook.
4) After all repairs are finished, interact with the main control switch or final prompt. If the lights and music start, the event should remain active for players who enter the area later in the same match.
Hotel Panorama Disco Room Puzzle Risks, Myths, and Smarter Play
Do not treat the disco like a safe room
The music is fun, but it can hide footsteps. That matters. A squad taking selfies under the lights is a squad that may not hear a third party sliding into the basement with bad intentions.
There are also reported geometry issues around basement planters, floor gaps, and awkward collision spots. I would avoid jumping around while searching for prompts, especially if carrying valuable gear. Getting stuck in a party room and losing your kit is funny only when it happens to someone else.
Common myths worth ignoring
Some players assume the puzzle must unlock a hidden chest or reputation bonus. There is no reliable proof of that yet. There is also no solid confirmation that the disco attracts AI from outside the basement, though the sound can absolutely change how human players read the area.
Side note here: if someone claims the lights are visible across the map, ask for a clip. The safer assumption is simpler. You are making noise in a confined basement, and confined basements are where confident squads go to become cautionary stories.
A practical squad plan
Send one player to handle repairs while two hold angles. Rotate only after each interaction finishes. If you are solo, repair one point, pause, listen, then move. Slow, but sane.
Before your next Riven Tides run, stash a few electrical parts, mark the southeastern basement route, and decide whether the Hotel Panorama Disco Room puzzle is the mission or just a detour; if you need quick item support between raids, eznpc can fit that prep loop without turning the secret into a grind. Then go light it up before the lobby turns the hotel back into a war zone.
ARC Raiders Disco Puzzle Tips Shop Gear Deals at EZNPC
EmberPhoenix
