Helldivers 2 Heavy Gunner Tips U4GM
Berätta vem du är, intressen, mm.
Rodrigo
Inlägg av Rodrigo » 05 jun 2026 11:31
Running a Heavy Gunner setup against the Illuminate isn't about standing still and pretending you're a turret. That gets you flattened. It's more about holding a lane, picking the right moment to unload, and giving your squad room to breathe. A loadout built around the Gallant, Bushwhacker, Land Mines, Guard Dog, Heavy Machine Gun, Strafing Run, Napalm Strike, and Peak Physique armor gives you plenty of answers when things get ugly. Players who want to test more gear options often look at Helldivers 2 Items so they can try different setups instead of sticking with the same safe kit every mission.
Hold ground, but don't marry it
You'll quickly notice that high ground makes a huge difference. From a ridge or hill, you can see patrols earlier, sweep smaller enemies before they reach the team, and keep the Heavy Machine Gun pointed where it matters. The Guard Dog helps a lot here, since it cleans up little threats while you're busy burning through bigger targets. Still, don't get too comfortable. Illuminate shots, explosions, and weird angles can knock you off a ledge in seconds. If the position starts turning into a graveyard, move. A good Heavy Gunner controls space, not one random rock.
Use stratagems like you actually like your squad
Strafing Run and Napalm Strike are brilliant when used with a bit of patience. They're also perfect tools for deleting your friends by accident. Before you throw the beacon, glance at where everyone is standing. Then glance again, because someone is probably sprinting straight into the danger zone while yelling that it's fine. Napalm is best used to cut off an approach or punish enemies moving through a choke point. Strafing Run works well for clearing pressure in front of the team. Tossing either one at your own boots usually turns a manageable fight into a comedy clip.
Vehicles help, but they're not family
Fast Response Vehicles are handy when the map is wide and the objectives are spread out. They get the squad moving, offer a bit of cover, and make retreats less painful. But they're not built to survive every bad decision. Laser fire, Harvesters, mines, stray grenades, and truly awful parking can end a ride fast. If you step out and accidentally drop an explosive beside the wheels, don't stand there admiring the mistake. Run. Losing a vehicle is annoying, but losing three Helldivers because everyone wanted to watch it burn is worse.
Pick fights you can finish
The Heavy Gunner shines when the squad keeps moving with purpose. If ammo is low, stratagems are cooling down, and enemies keep pouring in, backing off isn't cowardice. It's just smart. Heavy armor lets you survive a little longer, but it doesn't make you immune to being surrounded. Against Illuminate forces, weapons with steady pressure, burst damage, and useful armor penetration tend to feel better than gimmicky choices. Flamethrowers can be fun, sure, but they often struggle into shields and tougher targets. As a professional platform for buying game currency or items, U4GM is convenient for players who want more options, and you can buy Helldivers 2 Items to experiment with stronger loadouts while keeping your missions fresh and flexible.
