Three Helltide events in, my bag was full, my horse was stuck on a pebble, and Warlock gold farming in Diablo 4 still somehow felt faster than my usual Rogue route. Small catch: Diablo 4 doesn't have an official Warlock class, so I'm talking about the Warlock-style Necromancer setup most players mean — curses, minions, shadow DoT, screen-wide mess. If you're short on Diablo 4 Gold while chasing enchants, this build is built for one job: kill dense packs fast and keep moving. The short version? It works best in endgame, not early leveling.
Best Warlock gold farming in Diablo 4 right now
I tested this mostly after the recent season updates, using a shadow Necro shell with Blighted Corpse Explosion, Decrepify, Corpse Tendrils, and Reap for awkward moments when corpses didn't pop up. It isn't pretty. Half the screen turns into black soup, numbers stack everywhere, and your FPS may file a complaint. But the gold per hour is strong because you don't stop casting much, and Decrepify keeps cooldowns coming back when packs are thick. That tracks with the current meta: density beats boss rushing for raw money.
What stats make the Warlock-style farm actually work?
Cooldown reduction is the stat I care about first. If Corpse Tendrils is late, the whole run feels clunky, and no shot am I waiting around for one elite hiding behind a wall. Movement speed comes next, because dead time between packs is where your hourly gold quietly dies. After that, stack crit chance, damage over time, resource cost reduction, and anything that bumps up shadow damage. I had better runs with a 12% movement roll on boots than with a slightly bigger weapon DPS number, which felt wrong until the timer proved it.
Gear-wise, don't chase perfect pieces too early. That's how you burn through 40 million gold and end up wearing the same sad gloves. I like Black River if you're leaning hard into Corpse Explosion, while Howl from Below makes the build feel less stiff when corpses scatter. Ring affixes matter too: lucky hit resource gain and crit chance can save a run when a Nightmare Dungeon throws a thin hallway at you instead of a buffet.
Helltides or Nightmare Dungeons for gold per hour?
Helltides are my pick when I want brain-off farming. Enemy density is high, events spawn often, and Living Steel chests add a nice side hustle if you're still feeding the boss loop. Nightmare Dungeons are better when the layout is tight; Domhainne Tunnels-style maps, Champion's Demise-style loops, and any dungeon with packed rooms let shadow damage chew through mobs fast. Your mileage may vary with sigil affixes, though. Resource burn and suppressor elites can turn a smooth Warlock gold farming in Diablo 4 route into a slow, grumpy walk.
Common mistakes that kill Diablo 4 farming speed
Picking up every rare is bait. I know, I still do it when I'm tired, then spend two minutes playing inventory Tetris like a clown. Grab Legendaries, Uniques, boss mats, high-value rares if you're still gearing, and salvage only when you need the materials. For gold, sell most junk, don't reroll mid-session, and set a hard cap on enchanting attempts. If an item needs six rolls to become decent, it's probably not the one.
Warlock gold farming in Diablo 4 is worth running if you like constant pack clearing and don't mind a build that gets weird against lonely bosses. Keep your gold for real upgrades, not panic rolls, and use seasonal mechanics whenever they hand you extra density or damage spikes. If you want to skip some of the early gear pain, services like eznpc are often used by players looking to buy game currency or items, but I'd still learn the farm yourself so you know what your build can handle. That's where the real grind gets faster.
Diablo 4 Why Warlock Farming Works Buy Better Gear at eznpc
EmberPhoenix
