RobertD skrev:Nisse skrev:Perfekt i en Foamlance.....
Hur blandar man då? Som vanligt = en skvätt Concept och sedan toppa upp med varmt vatten i foamlancen?
/Robert
1:7 - 1:15.....Foamlance
Motortvätt 1:3
Kemspruta karosseri 1:15
Högtryckstvätt 1:7
http://www.hex.co.uk/MSDS/Concept/DELTAFORCE.pdf
Incredible Cleaner !: Removes the complete range of
stubborn and tenacious road traffic film and dirt.
Dried/baked on flies and insects simply dissolve
away !
Paint & Trim Friendly: Kind to paintwork, trim and
vehicle signwriting. Will not mark or dull surfaces:
totally safe cleaning action even with repeated use.
Wax Effect: Leaves paintwork clean, bright, reflective
and with water beading surface enhancers.
Super Concentrated: Gives dramatic savings when
pre-diluted before use (see directions).
Versatile: Can be used hot or cold, ONE professional
product for:
TRAFFIC FILM REMOVAL: State-of-the-art
performance.
SUPER DEGREASING: engines, chassis, chains, fork
lift trucks, plant hire.
DEWAXING: as a manual Co-polymer Dewaxer.
Floor Cleaner: Superb industrial floor cleaner for both
painted and tarmac surfaces.
Environment Safe: Fully biodegradable to EC
standards; contains no solvents, no phosphates, no
silicates.
DIRECTIONS : Delta Force Plus is a fully
concentrated product which must be pre-diluted before
use. Normal method of applications is by Low Pressure
Spray, Proxima Brush (manual cleaning) or High
Pressure Application. See application note before use.
